Group: DynoMotion Message: 5271 From: roa_controls Date: 6/20/2012
Subject: Mcode Bit Assignment
My machine is multi function and depending on which mode is selected I would like to run different tools with the same gcode.
Plasma M3 to set bit 152
Mill M3 to set bit 153
How can I programmatically assign a bit to an mcode before executing the ngc file?
Group: DynoMotion Message: 5272 From: roa_controls Date: 6/20/2012
Subject: Re: Mcode Bit Assignment
I see some dialog about this in the last couple of days... Guess I should have done a little searching on this topic first. I'm using 4.28 and don't see SetMcodeAction or GetMcodeAction.
--- In DynoMotion@yahoogroups.com, "roa_controls" <sdavenport.roa@...> wrote:
Group: DynoMotion Message: 5273 From: himykabibble Date: 6/20/2012
It's kinda buried:
KM_Controller.CoordMotion.Interpreter.SetMcodeAction();
For example:
KM_Controller.CoordMotion.Interpreter.SetMcodeAction(3, MCODE_TYPE.M_Action_SetTwoBits, KMIO["SpindleCW"].ID, 1, KMIO["SpindleCCW"].ID, 0, 0, "SpindleCW");
Ray L.
Group: DynoMotion Message: 5274 From: Tom Kerekes Date: 6/20/2012
It isn't clear to me what you are asking.  Are you trying to do this from your own C# application or from Mach3 or KMotionCNC?
But you might handle it from a KFLOP C Program.  For example you might use a Virtual IO bit (#48) to select the machine mode mode you are in. 1=mill 0=plasma.  You could then create User Buttons or M Codes to change mode.  The M3,M4,M5,Spindle C programs could then test the current mode and do the appropriate thing.
Group: DynoMotion Message: 5275 From: roa_controls Date: 6/20/2012
Thanks Ray,
The .Interpreter.SetMcodeAction() method is not exposed in my 4.28 build of KMotion_dotNet.dll. I did a search in the source and it's not there. I do see it 4.29. I have a custom build to expose COM to VB6 so I'll need to modify 4.29 and rebuild it. For not I'll just activate/deactivate my tools before/after I execute the ngc file. Unless someone has a better idea. Maybe a C program to interpret the Mcodes and set the bits?
Shannon
> It's kinda buried:
> For example:
> Regards,
> Ray L.
Group: DynoMotion Message: 5276 From: roa_controls Date: 6/20/2012
I need to change the bit that M3, M4, M5 controls form my VB6 program. I'll try it with a C program.
Shannon
> Hi,
> From: roa_controls <sdavenport.roa@...>
> Sent: Wednesday, June 20, 2012 7:40 AM
> Subject: [DynoMotion] Re: Mcode Bit Assignment
